ALF 33, zazatte, tof1986, jack_here, oxid974 et 16 utilisateurs inconnus nã©oprene Invité | article CAV by Alexandre
http://www.polkaudio.com/caraudio/ [...] sr/sr6500/
What every car needs: better drivers
Based on technology adapted from our top-of-the-line award-winning LSi in-home series, the Polk Audio SR6500 Signature Reference Series 6 1/2” Component System is for people who want the highest-performance sound for their high-performance wheels.
The SR6500 can be used either as a separate component system or converted into the best dang coaxial speaker on the planet.
The Sweeter Tweeter
The tweeter can be used either as a separate component or post mounted coaxially with the driver. Two flush mount cups (straight and angled) and two coaxial posts (straight and coaxial) are provided for the ultimate in installation flexibility.
* 22mm Ring Radiator Tweeter - Ring radiator tweeters have inherently few performance-robbing resonance modes. The result is flat, extended frequency response beyond 40kHz, low distortion, excellent dynamics, exceptional detail and transparency.
* Neodymium Motor Structure with Faraday Cap The copper “Faraday Cap“ on the pole piece flattens the impedance curve, lowers distortion, extends and improves high frequency response.
* High Frequency Waveguide Prevents phase cancellations for smooth, uniform frequency response and wide dispersion. The Driver
* Aerated Polypropylene Cone: The mid/bass driver cone is Aerated Polypropylene in which air is injected into Polypropylene to produce a honeycomb structure that serves to stiffen and damp the cone without adding mass. This is the same cone technology employed in Polk‘s critically acclaimed LSi Series audiophile-grade home speaker line.
* Removable Phase Plug for smooth, flat frequency response even off-axis. Remove the phase plug and replace it with either a straight or angled tweeter mounting post to transform the SR6500 into the absolute best coaxial speaker on the planet.
* Butyl Rubber Surround- Further damps cone resonance for wider response and lower distortion. High resistance to UV and temperature extremes means long life and reliability.
* Neodymium Magnet Structure - Finite Element Analysis (FEA) design makes the powerful neodymium magnet more linear for lower distortion and higher definition. Small Neo magnet makes the SR6500 easier to fit into more locations and vehicles.
* Die Cast Aluminum Basket for greater resistance to resonance.
* 2 1/2” Mounting depth plus supplied spacer rings ensure easy installation into a wide variety of cars.
* U.S. & Euro hole patterns to line up with the mounting screw holes of virtually any vehicle.
* 1 1/2” Voice Coil For better power handling and bass output.
* Polyimide Voice Coil Former for high thermal stability (rated to 220°C) high power handling and low mass.
* 4-Way Gold Plated Input Terminals Corrosion resistant terminals accept fastons, spade lugs and bare wire.
* Vent Holes in the basket equalize air pressure on both sides of the spider for more linear travel, flatter frequency response and lower distortion.
titben | je sais pas pourquoi mais ça me donne envie de tester |
Bass__Ton | c'etait mon futur kit...mais j'ai du arreter...
Qui se lance  |
nã©oprene Invité | Citation :
Polypropylene ... honeycomb
un croisement de MBQ & d'Aliante
... à vomir ... |
titben | c'est ring chef donc ça marche  |
bouss | Pour ceux qui ne pratiquent pas le Néoprène (au sens littéral bien sur), il convient de placer la remarque précédente "un croisement de MBQ & d'Aliante ... à vomir ..." dans le cadre des autoconclusions des gens "bien pensants", engoncés dans leurs idées reçues et plaidant à qui veut bien l'entendre que telle ou telle technologie ou produit "ne peut pas marcher"
Il faut également reconnaitre à Néoprène un certain gout pout le second degré et l'art de la diversion, ce qui pourrait incidieusement conduire à interpréter la remarque précédente par : laissez moi ce produit pour mes prochaines recherches et développements 8) |
habibzx | Citation :
8O ouf, pour une fois que c'est traduit. merci. |
titben | Citation :
j'apporterais une légere correction.
étant donné que de nos jours l'efficacité d'un HP, ou tout du moins son rendu virtuel se mesure à son taux de papier et au diamètre de son tweeter, la phrase devrait être entendue selon la manière suivante : lachez moi les HP pour mon J9
en même temps je peux me tromper je suis pas nordiste |
nã©oprene Invité | non, et tu le sais
c'est comme si je te demandais si tu préfères le whisky ou la bière
je suis rassuré de constater que je ne suis pas le seul à juger avec les yeux
ça c'est bien dit ça  |
