Vente de matériel : Pooky et 24 utilisateurs inconnus werner | http://bilstereo.just.nu/
au fait, en passant : notre ami a vendu sa golf 4 sur laquelle nous avons tous bavé ( il a enlevé le matos ).
il a déja acheté une autre et s'imagine une install
top secret pour le moment... |
fxmartin | tout simplement impressionant 8O |
especiosa | Citation :
vivement la nouvelle..... |
tramfr | Salut,
c'est quoi donc la batterie (Génésis) qu'on appercoit sur la vue du coffre?
Il me semble en avoir vu aussi ds les install à Steven Sailler.
Ca parait pas bien gros pour une seconde batterie
@ bientot |
Luis (ECS) Le collectionneur | 2 Batteries in 1 ODYSSEY® batteries combine in one box the characteristics of two separate batteries. It can deep cycle (be recharged) as well as provide enormous cranking power. Military Grade Only Hawker ODYSSEY batteries are based on the same battery technology offered by Hawker to the military for aircraft and tank batteries. Odyssey batteries are of military grade and have endured rigorous tests that demonstrate their overall ruggedness and exceptional tolerance of mechanical abuse. Superior cranking and fast charge capability The 5 second cranking power of ODYSSEY® batteries is double to triple that of equally sized conventional batteries, even when the temperature is as low as - 40°C. Also, with simple constant voltage charging (alternator or independent charger), there is no limitation on the inrush current, so the user is assured of a fast charge. Specs: Length 7 in. Width 3 1/16 in. Height 6 5/8 in. Drycell Battery Without Metal Jacket 12 Volt 16 Ah @ 10hr rate 220 CCA 680 Cranking Amps for 5 Seconds 24 Minute Reserve Capacity Cycle life @ 77°F 400 at 100% DOD -40°F to 140°F Temperature Range Replaces DYNA-BATT 5575B, 5575C doc PDF: http://www.batterymart.com/pdf_files/odyssey_guide.pdf Features: 12 Year design life and 6 to 10 year service life 99.9% pure lead providing minimal plate corrosion Explosion proof Corrosion proof 2 to 3 times the cranking power of equilivant size battery Spill and leak proof Superior vibration resistance Fully Charged out of the box When fully charged can be stored for up to 2 years at 77°F May be installed on its sides at any angle without sacrificing performance attributes Military grade version of the Hawker Genesis 2 Year Full Powersports Warranty Made in the USA Note: Please check dimensions and terminal configuration to ensure this is the proper battery for your application.
tramfr | Merchi bien msieur Luis,
et plus concrettement, quelqu'un aurait il déja testé cette batterie?
un prix??
@ bientot |
