18 utilisateurs inconnus ludobrev | Salut tout le monde j'aurai voulu savoir si quelqu'un d'entre vous aurai essayé le dynaxorb de chez dynamat dans un caisson pour savoir si sa avait amélioré la qualité des bass |
Description
Dynaxorb is black, energy absorbing, and sound diffusing advanced polymer square. Dynaxorb eliminates Speaker Back-Wave Noise and Distortion. Dynaxorb eliminates back-wave speaker distortion that colors sound and confuses imaging by using a combination of energy absorbent material and the technology known as “faceting”.
Acoustic Properties
Back wave distortion, a common problem with every speaker, occurs when your speaker sends the same sound out the back as it does out the front. If this rear sound wave energy is allowed to bounce back and return to the speaker, it interferes with the speaker’s ability to operate properly causing back-wave speaker distortion. Dynaxorb eliminates back-wave distortion using Sonic Stealth Technology. Dynaxorb absorbs, diffuses and attenuates the sonic energy directed towards it. Removing back-wave interference from the speaker allows every speaker to produce the full quality potential it was designed for.
Applications
For automotive use, Dynaxorb is most effective when installed behind speakers and inside subwoofer enclosures. When used with car speaker door installation, install Dynaxorb to the panel directly behind the speaker. In subwoofer enclosures, use multiple Dynaxorbs to line the enclosure wall that is directly behind the subwoofers. For home/home theater use, use Dynaxorb behind in-wall installation speakers and inside speaker and subwoofer cabinets. Lining Dynaxorb behind in-wall speakers will not only eliminate back-wave speaker distortion it will also decouple the sonic energy from the in-wall speaker reducing the unwanted sound radiated through the wall into the adjacent room.
Installation
Dynaxorb comes in 6” x 6” squares and can be used individually with smaller speakers or tiled together to line the opposing wall inside subwoofer enclosures.It can be easily attached to any given substrate with a cyanoacrylate adhesive. Dynaxorb can be trimmed to fit using a knife or scissors. Remove dust, grease, moisture and other foreign matter from the application surface. For best results, treat the area behind the speaker with Dynamat Xtreme then install Dynaxorb directly over the Dynamat.
Specifications
Red denotes metric measurements
Appearance:
Black, advanced polymer square Thickness:
¼” (6.35mm) Weight:
0.34 lbs. per 6-1/16” square
(168 g per 154mm square) Hardness:
<10 Shore A Density:
69.6 lbs./ft3
(1120 kg/m3) Rebound Resilience:
<15%Tensile Strength Water Absorption:
None Storage:
Store in a cool dry place >Recommended Adhesive:
Cyanoacrylate adhesive
HaRdCoRe430 | :? et kwa, et ça marche vraiment ... ??? |
ludobrev | Je les es dejà
Je vais en mettre quatre dans mon caisson avant derrière le sub le pense que sa va améliorer le résultat car ma paroi du caisson coté aimant est parrallele à celle qui fixe le sub |
KazimiR CorporatioN | C'est a mon avis grandement comparable a du Plain Chant |
ludobrev | A mon avis c'est encore plus efficace le fait qu'il y est plain d'angle pour casser les ondes!
Par contre contrairement a se que l'on pourrai croire sur la photo c'est une matière extremement souple et amortissante , je peux vous le dire car je l'ai actuellement entre les mains |
moana | esperont seulement que c est bien le produit que tu tiens et pas ta biloutte
ok ok je m en vas! |
boomako Spirit Beetle | Bonsoir, a quand les miens, et le reste d'ailleurs?
Nota: produit éprouvé en competition mondiale, ainsi que le reste des produits de cette marque, d'après le revendeur qui se trouvait au PTS.
Allez voir sur le site d'audio france diffusion, vous pourrer télécharger les fiches techniques. |
ludobrev | Tous le matos dynamat est là par contre pour le reste je ne sais pas!
oh fait salut seb! |
boomako Spirit Beetle | Bonsoir, salut ludo, génial je vais pouvoir continuer mon insonorisation comme il se doit. |
michael2 | et combien y cout ton bout de mousse amortissante ?
passke le plain chant c'est bien joli mais vu le prix hors de question que j'en mette un jour ! |
YES75 | Salut,
Ben alors donne nous les résultats de ton expérience avec le Dynaxorb!!
Dynamat propose que ça comme produits?
Pour audio france diffusion je trouve rien, t'as pas l'adresse du site ?
Tarde pas trop pour les résultats car je vais bientôt commencer mon installe.
CHIAO!!!! |
boomako Spirit Beetle | Bonsoir, voir sur www.a-f-d.com, le lien marche, pour savoir si le dynaxorb est efficace, faudrait que je l'ai reçu et que je le monte. |
YES75 | Super, MERCI!!!
Ben voila, c'est pas ils proposent toute une gamme pour toute les parties de la voiture.
Si qq'1 a essayé qu'il me donne des echos du produit essayé.
COOL MERCI ENCORE. |
Ce n'est pas un poisson :!:  |
olive64 | selon ce que m'as dit luis, le dynaxorb est bien mieux que le plain chant
pour moi c'est pour metttre derriere mes woofer et c'est surtout (tjs selon luis) pour ameliorer les medium et bas medium de mon R6a
pour le moment j'ai preferé faire des test de different materiau et me faire mon propre avis a ce sujet mais je compte bien essayer ce dynaxorb : c'est qd meme etudié pour, et je fais confiance a luis dites le si je raconte ma life |
cox-nox | j'avais deja vu le speaker kit mais pas le sub kit ,t'as trouvé ça ou ? en bass reflex on doit aussi cassé l'onde ? |
