fabrice1971, kebass, funkysoulstory et 17 utilisateurs inconnus
avis sur les caracteristique d un amplie alpine..
n°48565
xinob
Posté le 18-05-2004 à 19:05:11  profilanswer
voila les caractersituque le amplie alpine MRP-F257
pouvez vous me dire ce que vous en penser ..svp
SPECIFICATIONS
RMS Power (at 14.4V, 20Hz—20kHz)
25W x 4 (0.08% THD) into 4 ohms  + 80W x 1 (0.3% THD) into 4 ohms
35W x 4 (0.3% THD) into 2 ohms + 80W x 1 (0.3% THD) into 4 ohms
70W x 2 (0.3% THD) into 4 ohms + 80W x 1 (0.3% THD) into 4 ohms
General
Frequency Response .................................... 10Hz—50kHz(+0,-1dB)
Signal to Noise (S/N) ............. 100 dBA (referenced to rated power)
Input Sensitivity (for rated power) ...................................200mV to 4V
Slew factor ..................................................... greater than 5
input Impedance .............................................. 10k ohms (line input)
........................................................... 15 ohms (speaker level input)
Speaker Impedance ...............4 or 2 ohms (stereo), 4 ohms (bridged and sub output)
Dividing Network ............... Fixed 80Hz HP(18dB/oct.) and 50Hz—200Hz LP(12dB/oct.)
Power Requirements ...................... 11—16V DC (negative ground)
Heat Sink (WxHxD) ....... 226mm x 53mm x 275mm (8-7/8"x1-7/16"x11" )
Foot Print (WxHxD) ....... 246mm x 53mm x 275mm (9-5/8"x1-7/16"x11" )
Weight .......................... 3.1kg(6lb. 13oz.)
ou les caracteristique general :
5/4/3 Channel
Top Mounted LED Power Indicator
MOSFET Power Supply
DC-DC PWM Power Supply
No Current Limiting
Double Buffered Pre-Amp Input Circuitry
Discrete Pre-Amp Stage Darlington Bi-Polar Outputs STAR Circuitry
Duo ß Feedback Circuit
MultiMode™
Fixed HP Crossover (Front and Rear) Adjustable Subwoofer Crossover Continuously Adjustable Gain Control Gold Plated RCA Input Connectors
Gold Plated Screw-Down Power Terminals
Low Profile Chassis
Speaker Level Inputs
merci d avence...
