15 utilisateurs inconnus Brax | Juste comme çà.....c toujours chouette de voir des gars vendre du matos (un caisson amplifié 2 subs) à 11.000 Eur !!!!!!!
ET 181 KG 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O 8O KRELL MASTER REFERENCE SUBWOOFER - MRSSUB The Master Reference Subwoofer is without peer among low-end transducers. With a specially tuned, 2600 watt Krell amplifier at its heart, the Master Reference Subwoofer is capable of devastating bass reproduction. Its 1" thick aluminum housing is impeccably finished and loaded with two 15" high-excursion drivers. Equipped with a Krell designed, active, fully programmable built in crossover, the Master Reference Subwoofer is at home in the most exotic music and home theater systems alike. Specifications: Type Powered Subwoofer Enclosure Type Acoustic suspension Drivers Two custom-built 15-inch woofers with 3-inch peak-to-peak excursion Power Amplifier Purpose-built Krell 2600W amplifier Peak Output Greater than 120dB SPL Technical Features One-inch thick solid aluminum enclosure for entire chassis with 2-inch thick baffles Digital Crossover Controls Independently selectable parameters for low-pass and high pass. Profile Type Bessel, Butterworth, or Linkwitz-Riley Slope High Pass, Adjustable in 6 dB increments from 6 to 24 dB/octave Low Pass, Adjustable in 6 dB increments from 6 to 48dB/octave Frequency Adjustable in 10Hz increments from 30 to 100 Hz Level Adjustable in 1 dB increments ±6 dB Inputs One set each: balanced, single-ended, CAST, and LFE Outputs One set each: balanced and single-ended, CAST high-pass, and bypass User Features Fully user-configurable crossover adjustments for slope, frequency, level, and filter type assignable to five memory presets Remote Control 1 handheld wireless Remote Connectors Krell Link in/out, 12 VDC (12 V trigger) in/out, 12 VDC LFE in, RC-5 in, bidirectional Frequency Response 20-100 Hz ±0.6 dB; -3 dB at 14 Hz Finish Black Dimensions 18.8(w) x 20.1(h) x 28.5(d) in. 47.8(w) x 51.1(h) x 72.4(d) cm Weight 400 lbs., 181.8kg All operational features, functions, specifications, and policies are subject to change without notification.
Moi qui pensais avoir du bon matos...j'vais me recoucher direct !!! |
belloubustou | et alors ?  |
Dominique... | Enfin du matériel de qualité pour sonoriser les char d'assaut, ca va juste réhausser encore un peu le prix du Leclerc  |
nã©oprene Invité | ça rentre pas dans une yaris ton truc :?
golgot | j'ai déja vu ce matos.si ce que Brax nous envoie en photo est une version audiomobile,alors ce n'est qu'un caisson de home ciné modifié pour tourner sous 12v.il doit exister depuis au moins deux ans,et le test que j'avais lu à l'époque insistait bien sur le coté terrifiant de ce truc pour possesseurs de salle de projection privée.la boite est en fonte d'alluminium,et il faut être minimum 2 pour le placer.si ça fait tomber le platre dans 60m²,ça doit faire imploser une twingo 8O enfin,avec la même thune,on doit pouvoir faire beaucoup plus thrash par sois-même...  |
malossi | Pour le prix d'une platine Krell pourrais me payer une civic Type R avec un son correct ca me fou le spleen ce genre de matos moi  |
Naickou2 | Citation :
J'annonce Platine Krell KPS 25 sc : 250 000 F (38 112€ pour ceux à qui ca fait mal de convertir )
Bon, y'en a qui vont la poser, alors je les devance :
"Est-ce que ça lit les MP3 pour ce prix?"  |
malossi |
Mdrrr t'es fou toi Pas de MP3 mais pour le prix t'as un double convertisseur 20 bits, un filtrage numerique a base de double DSP Motorola 56009 et HDCD Pacific Microsonics PMD 100
C'est un préampli, convertisseur, Lecteur CD pure souche audiophile!!! T'as deja vu un audiophile ecouté du mp3 toi??? c'est un truc inimaginable pour eux  |
michael2 | Citation :
ARF MDR !! c'est tout à fait ce genre de profil, à savoir que le CD est déjà tout juste toléré , bien qu'il ait progressé.
Le must étant le Vinyl sur platine à chassis en marbre pour les derniers intégristes, et alimentation par batterie et non pas par transfo !
définition exacte de l'audiophile home : " se contente de ce qui se fait de mieux à défaut de la perfection "
Pour le caisson présenté plus haut, connaissant la réputation de KRELL, ça doit être du serieux, car une marque de ce niveau de réputation ne saurait se tromper et decevoir sa clientèle. |
malossi | J'en ai vu une comme ca dans un magasin ou t'entres pas si tu montres pas un cheque en blanc lollll
La bestiole etait en vitrine et pesait la bagatelle de 40Kg en marbre noir polit c'etait assez somptueux mais la marque l'ai pas retenue  |
Je sais...
J'ai une platine aussi, qui ne lit pas les MP3 car c'est pas du tout la philosophie de l'animal.
C'était juste un peu d'humour...  |
Fred-ql | Les KRELL sont des références en la matiére avec, pour leur ampli, une réserve de courant extraordinaire et une sonorité de même.
C'est du tres tres haut de gamme. |
