ludobrev, ALF 33, bluesky74 et 24 utilisateurs inconnus stefane33fr Team Zayde ! | Bonjour,
Est-ce que quelqu'un aurait des infos sur ce genre de convertisseur ?
Alpine 3900 D/A .
Comment il fonctionne ? Que fait-il ? Et quelques données techniques aussi.
Merci. |
richard r | than never!
The 3900 is a high end D/A convertor which has seperate PCB's for both the analogue/digital section. Its also supposed to extend the frequency range past 20kHz and give a 'natural' sound. The D/A was intended for Class A amplifiers and has outputs for 'Front', 'Rear' & 'Non-fading'. It also has a Fixed level output RCA which we will cover later. The D/A can handle 32k, 44.1k (CD), & 48k (DAT) inputs
Basically if you want to use it with an old school set-up, this is how you're supposed to set it up.
Alpine 7618R / 7619R Headunits - these are both tape decks which have the option of having a 'fixed' output for the RCA output section on the deck.
The 3900 can only accept a 'fixed' RCA input, so you need one of these decks for the analogue section to work correctly. If you stick a bog standard deck on without this feature it will not work - trust me I've tried it
The 3900 has 3 digital inputs which range from 'changer', 'master', & 'aux'. The 5957s/5959s changers were the intended targets for the 3900 as they had digital outputs.
The 3900 also utilitises an M-BUS connection which goes from the headunit straight into the D/A itself. This is so you can use the volume controller on the headunit to control the overall volume. The D/A also has an M-BUS out which then connects to the changer as normal to power it etc. The wiring diagram is on www.alpine1.com if you need any further clarification on this.
From then on you use the Front, Rear & Non-fading outputs RCA's which go to the amplifiers.
Saying all of that, you can still use the 3900 with todays headunits which utilise an optical out on the deck - with a few niggles might I add.
Lets say for example you have a 7998R - you can wire it directly from the optical out straight into the 'changer' digital input - be aware that you will have to use the 'fixed output RCA' on the D/A.
From the fixed D/A output you will need a device to control the volume - Audiocontrol Master Volume Controller or something like a Three.1 will suffice as that has a line driver/EQ/crossover/volume control all in one..
From there you will just need to hook upto the amplifiers as normal and wallah you're all done and dusted
The only let downs to using the more uptodate method is that you will;
A) Loose your radio
B) More expensive as you need to purchase a volume controller etc.
C) longer lengths of RCA cables - unless you have the D/A & amps up front etc...
I love the 3900 personally, I find the sound to be superior to the 7909 in most aspects but then again I love a 7909 in the dash lit up at night
Hope that helps, my hands are tired... and I pray to god you're still on this forum to read the reply LOL.
Paul.
bon ok c est en anglais mais bon..
j ai un 5959 en stock...va savoir?
-TAZ- | et en francais cela veut dire koi a peu près?
PS : je suis sérieux dans ma demande |
narbi | Traduction google (qui vaut ce qu'elle vaut donc ...) :
Les 3900 est un convertisseur à extrémité élevé de D/A qui a des cartes de seperate pour tous les deux section analogue/numérique. Les ses également supposés développent la gamme de fréquence après 20kHz et donnent un bruit « normal ». Le D/A a été prévu pour des amplificateurs de la classe A et a des sorties pour le « avant », le « arrière » et « Non-se faner ». Il a également un résultat de niveau fixe RCA que nous couvrirons plus tard. Le D/A peut manipuler les entrées 32k, 44.1k (CD), et 48k (DAT) Fondamentalement si vous voulez l'employer avec une vieille installation d'école, c'est comment vous êtes censés l'établir. 7618R/7619R alpine Headunits - ce sont les deux plate-formes de bande qui ont l'option de avoir un résultat « fixé » pour la section de rendement de RCA sur la plate-forme. Les 3900 peuvent seulement accepter les entrées RCA fixes, ainsi vous avez besoin d'une de ces plate-formes pour que la section analogue fonctionne correctement. Si vous collez une plate-forme standard de marais dessus sans ce dispositif que cela ne fonctionnera pas - faire confiance que je je l'a essayé Les 3900 a 3 entrées numériques qui s'étendent du « commutateur », du « maître », et « aux. ». Les commutateurs 5957s/5959s étaient les cibles prévues pour les 3900 car ils ont eu les sorties numériques. Les 3900 aussi utilitises un raccordement de M-BUS qui va du headunit directement dans le D/A lui-même. C'est ainsi vous pouvez employer le contrôleur de volume sur le headunit pour commander le volume global. Le D/A a également un M-BUS dehors qui se relie alors au commutateur en tant que normale pour l'actionner etc. Le diagramme de câblage est sur www.alpine1.com si vous avez besoin de toute autre clarification sur ceci. Puis dessus de toi employer l'avant, l'arrière et les sorties RCA de Non-effacement qui vont aux amplificateurs. Disant toute la cela, vous pouvez encore employer les 3900 avec les headunits d'aujourd'huis qui utilisent une sortie optique sur la plate-forme - avec quelques soupçons pourrais j'ajouter. Disons par exemple que vous avoir un 7998R - vous pouvez le câbler directement de la sortie optique directement dans l'entrée numérique de « commutateur » - vous rendiez compte que vous devrez employer « le rendement fixé RCA » sur le D/A. Du D/A fixe produit t'aura besoin d'un dispositif pour commander le volume - le contrôleur principal ou quelque chose de volume d'Audiocontrol comme un Three.1 suffira comme cela a une ligne commande toute de driver/EQ/crossover/volume dans une. Là de toi devra juste s'accrocher jusqu'aux amplificateurs comme normale et wallah que vous tous êtes faits et époussetés Les seuls laissent des bas à employer plus de méthode d'uptodate sont que vous ; A) Desserrer votre radio B) Plus cher en tant que toi devoir acheter un contrôleur etc. de volume. C) plus de longueurs de RCA câble - à moins que vous avez le D/A et les ampères vers le haut de l'avant etc…. J'aime les 3900 personnellement, je trouve le bruit pour être supérieur aux 7909 dans la plupart des aspects mais de l'autre côté amour d'I des 7909 dans le tiret allumé la nuit Espérer que les aides, mes mains sont fatiguées… et je prie à un dieu que vous êtes toujours sur ce forum pour lire la réponse LOL. |
titben | recherche sur onk, on s'y était interessé avec mike y'a 2 ans.
celui qui trouve la chaine avec 7909, 3900, 5959 et amplis 33XX  |
