vive google...
Mounting Dimensions EX10T3 EX12T3 EX15T3
Mounting Diameter 235 mm 285 mm 361 mm
Mounting Depth 164 mm 186 mm 215 mm
RECOMMENDED ENCLOSURES EX10T3 EX12T3 EX15T3
SEALED ENCLOSURE
Net Volume: 19 l 32 l 68 l
PORTED ENCLOSURE
Net Volume: 35 l 65 l 135 l
Port Diameter: 1 x 10 cm 1 x 10 cm 2 x 10 cm
Port Length: 26 cm 18 cm 26 cm
BANDPASS ENCLOSURE
Net Volume Ported Chamber: 20 l 28 l 56 l
Net Volume Sealed Chamber: 15 l 24 l 45 l
Port Diameter: 1 x 10 cm 2 x 10 cm 3 x 10 cm
Port Length: 15 cm 25 cm each 19 cm each
Important notes on enclosure construction
and cabinet damping!
For best results, we highly recommend the enclosures
to be constructed of either 22mm MDF (Medium
Density Fiber-Board) or 21mm birch plywood.
Each enclosure type must be damped according to its
function principle:
œ The sealed enclosure must be filled completely with
acrylic fibre, or - even better - lined with structured
PU-foam.
The inner walls of a ported enclosure should be
lined with structured PU-foam.
œ The sealed chamber of the bandpass enclosure has
to be filled with acrylic fibre while the ported chamber
remains free of any damping material.
WARRANTY
EMPHASER Inc. Wyoming, Michigan USA warrants this X-treme T3 woofer to be
free of defects in materials and workmanship for one year from the date of
purchase, contingent upon being installed in a proper enclosure as built or
approved by an authorized EMPHASER dealer.
EMPHASER Inc. will at its own discretion repair or replace any mechanically
defective speaker unit during the warranty period.
Should your EMPHASER woofer require warranty service, please return it to the
retailer from whom it was purchased. Please do not send any product to EMPHASER
Inc., Wyoming,U.S.A. Should you have difficulty in finding an
authorized EMPHASER service centre, details are available from the national distributor
in the country of purchase.
Abuse of the woofer due to excessive amplifier power, improper enclosure
design, amplifier clipping or physical damage is not covered under warranty.
EMPHASER Inc. Wyoming, Michigan U.S.A.
prévoir un caisson tres rigide...et un ampli tres musclé...
si tu as des questions telephone (comme l'avait d'ailleur précisé toche)
ici: Phone: 03 25 87 33 33 demande laurent ou le grand yaka...
