jack_here, 55speed, donka, 1 utilisateur anonyme et 23 utilisateurs inconnus lguedin Art-rache | salut tout le monde!
voila je n'ai pas trouvé beaucoup de renseignement et d'avis sur le ke macrom exs6 donc ba j'aimerais savoir ce que vous en pensez !
EXS6.0
16,5 cm 2 WAY SYSTEM
SPECIFICATIONS
Max power : 160 W
RMS Power: 80 W
Frequency response : 45 Hz - 25 kHz
Sensitivity : 90 dB
Woofer impedance : 4 Ω
Dimensions : 16,5 cm
Mouting depth: 59 mm
LOUD & CLEAR - HIGH-END FIBERGLASS CONE WOOFER WITH CHROME BULLET
This new cone combined with the bullet provide an exceptional sound quality result.
Ø25MM HIGH-END LINEN DOME TWEETER WITH INTERNAL NEODYMIUM MAGNET
Large diameter for better response and tremendous energy. The tweeter is ferrofluided for better cooling
and larger power handling. Linen dome for softness and precision.
Ø32MM TIL VOICE COIL ON THE WOOFER
For fast air penetration and good thermal dispersion
ALUMINUM ARMED PVC BASKET
For optimal sound quality results, the basket is a ”dead noise” basket !
ADJUSTABLE TWEETER LEVEL IN THREE POSITIONS ON THE X-OVER
0 db, -3dB or -6db position, for good flexibility when installed in different cars
12DB/OCT EXTERNAL PASSIVE X-OVER WITH POLYPROPYLENE CAPS
PTC FOR ACTIVE TWEETER PROTECTION
When the power or/and the distortion are too high, the ptc is protecting the tweeter
FIBERGLASS CONE
For great sounding, low frequencies and a total insensitivity to humidity
BULLET IN THE CENTER
To avoid stationary waves and ”sound from the nose” results
MULTI MOUNTING KIT FOR THE TWEETER
Every thing is included ! You can install the tweeter built-in, in surface or inclined.
CHROME PLATES / CHROME BULLET
For high-end technical design
MAX POWER 160W
80 W RMS, for an amp between 50 W and 100 W.
merci |
lguedin Art-rache | a oui j'avais oublié dsl
j'écoute bocoup de métal, hardcore etc mais aussi un peu de vieux rock, rock unplugged , reggai ( style tryo )
les portes seront insonoriser cet été  |
polosky | salut jen ai un actullement j'aime bien ca tape assez sec pourtt mes portes sont pas super insono par contre les aigus sont tres metalique et "criard"...bref le kit et bien ms faudrai trouvé d'autre tweet a leur mettre dessus
PS: je n'ai pas une ou 2 oreilles tres musical donc reprenai moi si je di des c***rie @+ |
lguedin Art-rache | merci de ta reponse !
j'ai actuellement des O² geyser 5 dans mes portes et j'ai branché cet aprem des tweeters macrom 5813 et j'ai franchement bien aprécié le changement ( bocoup moin agressif )
par contre je ne sais pas quelle série de tweeters comprend le EXS6 ?? |
lguedin Art-rache | personne d'autre n'a écouter les exs 6 ? |
poloblue | perso j'aime bien les 16 pendant un moment j'en et u 2 par porte et sa marchait tres bien sec et une bonne tenu avec un grave propre mais faut voir comment ut le monte et avec quoi tu l'amplifie  |
lguedin Art-rache | les portes vont etre insono et jver fairs des cales en médium .
le kit sera poussé par un srx4
et tes impression sur les tweeters ? |
poloblue | honnetement vraiment pas top  |
Luis (ECS) Le collectionneur | T'es gentil là, astrablue  |
lguedin Art-rache | arf a donc vos peu etre mieux que je retourne sur mon idée de davis 165 vt ?
pourtant g des tweeters marom 9813 et sa va comparer a des O² geyser mais bon je ne suis pas aussi calé que vous .... |
lguedin Art-rache | ou alors je peut avoir juste le kit sans les tweeters mais il me faudrait des tweeters adapter au courbes des filtres pour que sa marhe bien non ? |
poloblue | ba refait des passif et test avec tes twreet macrom ou passe en actif mais serieu pour avoir jouer avec les tweet macrom c'est vraiment pas sa par contre les 16 peuvent meme faire de la music douce hein luis  |
lguedin Art-rache | refaire des passif c a dire ? ( dsl je mi connais pas tro )
en actif non merci c pas pour maintenant ... |
poloblue | pas tu te refait a l'aide de composant t'elle que des condensateur des bobine et des resistance un boitier de filtrage comme celui de ton exs d'origine mais de bien meilleur qualiter et surtout avec les valeur que tu veu mettre toi comme filtrage  |
lguedin Art-rache | a oué eu ....
c compliqué non ?
car deja je ne sais mème pas quelle valeur de filtrage je veu mettre .... |
poloblue | non honnetement pas tant que sa fait un petite recherche sur le forum  |
lguedin Art-rache | oué ba je vais chercher sa !
sa me permetera donc de faire des filtres parfaitement accordé o méduim et o tweeters si g bien compris
faut voir aussi kel tweeters mettre ... |
aval.team | Juste pour savoir; peut il servir comme haut medium dans une configuration trois voies????? |
poloblue | pour etre franc le 16 du kit exs ne monte mais pas du tout en clair pour faire du grave oui mais pas plus
enfin d'apres moi  |
lguedin Art-rache | bon ba je laisse béton le exs6 vu tou les critiques qu'il a ....
je vais attendre plus longtime et prendre un dsl r6 ou r5 !
enfet entre le 13cm et le 16 ya bocoup de différence ? |
poloblue | ba la grosse difference se fera surtout sur le grave et l'impact du a la difference de taille de menbrane
mais je le repete les 16 exs sont tres sympa  |
tres simpa sof les tweeters ki braille de trop et les woofer ki tape pas assé ... |
poloblue | celui qui ta dis que le woof tape pas assez bas je pense qu'il a pas su les monter car je t'assure qu'il frappe
par contre rien a dire le tweet n'est pas top  |
enfin d'apres moi
peu tu mieu mexpliké si que tu voulais dire alors stp ? g du mal capter ... |
lguedin Art-rache | lol c simple et efficace !! les woofer du exs 6 par rapport au woofer du R6 ça donne coi ?
si les exs 6 son mieu je verai pour faire un kit woofer exs6+tweeters du R6 avec des filtres maison ( si possible ) :? |
Luis (ECS) Le collectionneur | Monte un R6A complet ou autre chose, et laisse tomber la salade woofs exs6 avec tweets T25 dls  |
lguedin Art-rache | oué je pense que je vais faire ça mais le prix est pas le meme ...
un R6a d'occaz cour pas les rues ... ( un exs 6 non plu remarque mais bon ...) |
poloblue | ecoute luis evite les melange de hp a moin d'etre sur de toi  |
lguedin Art-rache | ba nan je debute encore donc les conseil que vous me donnez sont tres utiles !
je vais attendre d'avoir plus de sou et d'avoir insoniriser l etou et modif mé porte etc et apres je prendrai un R6a
merci |
