sur le papier ca a l'air interressant, faut le prix après...
Max Power 960W
Line Output
Cooling Fan
New Amp Control System
New Amp Display
Voltage/Current Temp/fan speed
Amp to Amp Connection Via S-Video
New Design
960 Watts MAX Power
4 x 60 Watts RMS @ 4 OHM
4 x 120 Watts RMS @ 2 OHM
2 x 240 Watts RMS @ 4 OHM Bridged.
Tested at 14.4v
Signal/Noise Ratio 105dB
Frequency Response 5Hz-70kHz
24dB Crossover 50-200Hz, Low Pass Filter
12dB Crossover 50-200Hz, High Pass Filter
24dB Infrasonic Filter 15Hz
Variable Colour Power ON Indicator
Remote BMS Operation
Bass Frequency 60/80/100/200Hz
Bass Level -15 to +15 dB.
Dimensions - (WxHxD) 446x61x260mm
42A Fuse Rating
