roth, al Discussions pratique & montage : olivierm91, 1 utilisateur anonyme et 21 utilisateurs inconnus
mx406 et mx4000 mcintosh
n°147100
spino69
Posté le 05-10-2008 à 20:40:17  profilanswer
bonsoir est-ce que quelqu'un pourrait m'expliquer la différence entre ces 2 produits ?
merçi
n°147125
cox-nox
Posté le 06-10-2008 à 15:24:42  profilanswer
MX406 AM/FM tuner/CD player. Power guard. Low distortion analog audio controls. High voltage DC power supply for greater dynamic range. 8v output capability. 2-channel RCA auxilliary inputs. 4 channel RCA line high level outputs. Security code system. Cellular phone audio mute. Bass and treble controls. 4-way balance control. Digital quartz clock. TUNER: FM diversity. Audio store. Electronic quartz-locked PLL tuning. Presets for 6 AM and 18 FM. Signal actuated stereo control. CD PLAYER: Dual 20-bit D/A converters assure high level of performance. 8 times oversampling digital filter minimizes distortion and noise. Full logic CD controls. Track repeat. Last position memory. Track music search. CHANGER CONTROL: Direct disc select. 6-18 disc control capability. Fiber-optic digital input for CD changer. Size 2"H, 7"W and 6-5/16"D. Sold from . Last retail price $1000.00
MX4000/MDA4000 AM/FM tuner/CD transport. Power guard. Low distortion analog audio controls. High voltage DC power supply for greater dynamic range. 8v output capability. 2-channel RCA auxiliary inputs. 4 channel RCA line high level outputs. Security code system. Cellular phone audio mute. Bass and treble controls. 4-way balance control. Digital quartz clock. TUNER: FM diversity. Audio store. Electronic quartz-locked PLL tuning. Presets for 6 AM and 18 FM. Signal actuated stereo control. CD TRANSPORT: Full logic CD controls. Track repeat. Last position memory. Track music search. Fiber optic digital output. CHANGER CONTROL: Direct disc select. 6-18 disc control capability. Size 2"H, 7"W and 6-5/16"D. Sold from . Last retail price $2000.00
http://www.roger-russell.com/caraud.htm#controlcenters
http://www.mcintoshlabs.com/downlo [...] ources.pdf
n°147138
haupkins
Posté le 06-10-2008 à 22:58:56  profilanswer
MX4000 à une sortie numérique et entrée numérique mais il te faut le MDA4000 pour allé avec car la sortie numérique est propriétaire.
Le MX406 a les mêmes caractéristique au niveau du DAC que le MDA4000 cependant il est certains que vu qu'il combine MX4000+MDA4000 dans la seule place d'un toradio il doit y avoir quelques moins bien. (même si pour ceux ayant pu entendre les 2, la différence leurs parait minime)
en gros MX-406 tout en un, MX4000 sans MDA4000 inutile et si avec MDA4000 alors oui, un peu au dessus du MX406.
n°147140
richard r
Posté le 06-10-2008 à 23:19:02  profilanswer
Bonsoir...trouve toi un poste avec sortie Optique,je te vends un exellent convertisseur PPI DAC 348..ensuite tu te trouves un exellent préampli..et ca roule..
n°147162
spino69
Posté le 08-10-2008 à 00:35:20  profilanswer
merçi de vos lumières
au fait haupkins regardes tes mps  :wink:
