ALF 33, Dextoo, letitloveurdu44, kebass et 25 utilisateurs inconnus tugalês | Hi there. I'm from Portugal and i found this forum in another portuguese caraudio forum.
i've looked around and noticed that you all have already been in contact with both helix brand and focal.
can you help me telling your opinions about the two setups that i've written on the subject?
thank you all. |
tugalês | the sistem is under constrction...the amp i already have..the audison lrx5 to bi-amp the setup.
of course the setup is for SQ exclusively. I've never heard the helix ones but i've already heard the focal. i liked focal cause of some properties that i've found extraordinary. the tweeter has an Fs very low, because of that it can make mid tones very easy not compromosing the positioning of the woofer cause tones beyond 2000hz our ear can't notice from where they come from.there are the off-axis problem but that can be resolved exactly using the tweeter properties, we know that off axis problem is solved very easily on a 3 way sistem, but on a 2 way if the mid cuts to high maybe it can be a hell of a problem to solve..of course focal mid basses need an extra care...but any way they will work on a kick panel...
about the helix...i've eard wonders about them, but never in comparison with others setup's. |
bouss | blablabla, this is theory
what about the "music" you listen to: funk, classic, jazz, rock?
of course many of us listen to "everything", but what's your most critical track when comparing two setups? |
riga | T'es sur que c'est de l'anglais blablabla ? |
tugalês | i listen to everything too...jazz..bossa nova, rock, pop, hiphop,some house music...is there any significant differente between this two setup's listening to different music's?...strange notion... |
tugalês | what about DLS MS6a and Alpine SPX 177r? what do you think of it in comparison with this two?
thank you all. |
bouss | the Alpine have a very good and fast woofer, but the tweeter is a bit "light"
the MS6 is good but I would'nt put it on the same line as the others.
The Helix is quite "flat", very detailed, warm.
The Focal is a little more dynamic, but can also be "tiring" for some ears, with bad tuning or not adapted amplifiers.
Another brand that should interest you: Hertz
see ya  |
tugalês | i've already had hertz but the tweetrs are very metallic and they "hurt" a little bit the ears...
so you say that the helix one is the one with better behavior is it? or you think that i can look to other setuo that i've mencioned?
the tweter is a bit light from the alpine, what do you mean? thank you all.  |
tugalês | i've finally choose my speakers...after a little thinkin' and remebering my auditions...
i bought new ones Helix RS6 competition. i'll tell you later what i think of it in my instalaiton.
thank you all. |
