ALF 33, unbreakabledancer777, olivierm91, Dextoo et 27 utilisateurs inconnus Byron | Gardena, CA - (January 7, 2004) - Clarion Corporation of America, a leading manufacturer of mobile entertainment systems, some years back, created a very important thing for audiophiles around the world…they made a stereo truly dedicated to quality-rich, audiophile sound reproduction. Cut to 2004 and here we are again with the release of the DRZ9255. High grade Burr Brown and other precision internal components encompass this AM/FM CD Player to deliver true audiophile sound reproduction. Specially designed to keep stray electrical interference from high-end audio circuitry, the DRZ9255 employs a Copper Plated Chassis and an outboard DC/DC Converter power supply. The fluorescent display (VFD) allows superior visibility and tops off the re-mastered elegance and distinction that puts Clarion DRZ9255 in a category all by itself.
Consumers achieve the acoustic control they desire with 8-channels of RCA Outputs and built-in 4-way Digital Crossovers and Digital Time Alignment. The 5-Band Parametric EQ feature divides the frequency ranges into 5 bands of 1/3-octave frequencies, allowing fine adjustments of the Q (sharpness of EQ curve) and dB (gain). The Type K Burr Brown 24-bit D/A Converter is a sine magnitude-type that eliminates any audible noise and boasts a high signal-to-noise (S/N) ratio, creating broad dynamic music reproduction. Further, digital audio data read from a CD is over sampled at 96Hz to help reproduce the fine nuances of the music; and other digital signal processing utilizes a digital signal processor (DSP) from AKT Corporation, one of Japan's most respected names in component parts manufacturing. SRP: $1399.99
C'est peut etre ce modele?
En tout cas, ca fait plaisir de voir qu'ils vont sortir une succession à ces deux précédentes platines! |
l'aKRObate | Il faut absolument que Clarion change le design de leurs télécommandes...  |
Byron | C clair, les telecommandes sont ignobles, mais bons sur mes deux platines, je ne m'en suis jamais servi. Ca sert à rien si elle n'est pas au volant. |
poloblue | ba je prefere necore le design de mon 960rz
a celui de la nouvelle platine clarion
quelqun saurai ce quelle integre de plus que l'ancienne :?: DXZ945MP et mignon  |
fd14 | Citation :
Ce qui compte c'est de savoir si elle fait de la musique. D'aprés certaine source, la réponse est oui, et même trés bien. C'est surtout cela la bonne nouvelle 8) .
fd14 <¤> |
Byron | Citation :
Il est deja dispo au US. Tu as toute les infos sur clarion.com
D'ailleurs on le trouve a 500$ sur le net!!!
Niveau esthétique, j'adore mon 960z, mais j'avoue que celui ci est très sympa aussi. |
poloblue | ba a mon magasin il en as commander un donc je pense le tester des quil arrive
je vous dirai ce que sa donne  |
blue note | Il s'appel 948 en france et est disponible à 799 euros prix publique .
Il dispose d'un vrai alignement temps D'un reglage par attenuation du niveau de chaque canal.
De filtre passe haut et passe bas 50/80/120 hz pour les canaux sub et voies av et ar.
D'un equa paramétrique 3bande pour l'av et 3 bandes pour l'arriere.
D'un decodeur Pro logic II
Du dual Zone
Et d'un ecran tactile que je trouve tres peu pratique à l'usage :? Et d'autre broutille .
Je ne l'ai pas encore écouté. |
fd14 | Citation :
Tu veux dire que le DRZ9255 est importé en France :?: . Au PTS les gens du stand Clarion n'en étaient pas sûr du tout. Enfin tant mieux si c'est confirmé .
fd14 <¤> |
blue note | Le 9255 sera peut etre dispo Clarion étudie auprès de ses revendeurs le marcher potentiel 8)
J'attends des infos techniques sur cette source ,possibilité de filtrage.....etc...etc. |
poloblue | non je parlai de lautre  |
clio dls | salut,ben en ce qui concerne dxz948rmp,ben il est monté dans ma voiture depuis hier soir et que dire digne successeur du drx960.
en ce qui concerne l amplification interne elle desactivable,donc pas de chauffe du a l ampli  |
Byron | Citation :
Comment cela se fait que vous ayez deja vu ce modèle alors que le site clarion france ne parle pas encore de la gamme 2004?
J'aimerai bien en voir un sur lyon...
Tu veux pas faire des photos de la nouvelle interface? |
Byron | Au fait, si on utilise le DXZ948RMP avec un chargeur 12 Cd clarion, on peut utiliser du WMA/MP3 dans le chargeur, ou seul le lecteur de la platine l'accepte? |
ONCLE FUR | C'est un pmeu confus là...
Quelles ref sont dispo en france et à combien ???
tinkx |
Byron | Celui qui correspond au remplacant du 960z, c'est plutot le dxz948rmp qui à l'écran tactile et dont la design est assez sympa. Il est à 800€ environ, soit le prix du 960z et du 9575Rz a leur sortie à peu de chose près. |
Byron |
lien et manuel dispo aussi chez clarion-europe. Il y a qu'en France que le site est tjrs a la bourre... |
blue note | Venez chez les revendeurs Français qui en ont :? Vous pourrrez l'ecouter ,le toucher,prendre connaissance de ce qu'il peut faire  |
Byron | Citation :
Le seul truc, c'est qu'avec Clarion, c'est la croix et la bannière pour trouver ce genre de modèle en démo. Quand j'étais en Corse, je peux comprendre vu le marché que celà soit difficile. Mais à Marseille et maintenant à Lyon, c'est pareil. Quand on demande à Clarion où en trouver, ils te sortent une liste de feu vert et norauto énorme. Bien sur, il n'y a jamais ce genre d'appareil en stock. A Marseille, ils m'avaient même donné des adresses qui ne faisaient plus la marque depuis des années... Si tu as des adresses sur Lyon/Ecully, ca m'interesse bien. |
ONCLE FUR | Wé 8O 8O 8O Quel différentiel avec le prix espagnol (649 €)
Parle nous un peu de tes premières impressions !
Le debrayage de l'ampli interne semble être une bonne option !
L'écran tactile apporte quoi franchement ? |
blue note | Citation :
A mon avis sur une installe comme celle de clio DLs le clarion est plus la pour le look que pour son converto 24 bits
Un gadget pas pratique que pour le "touninge"
Même si ésthétiquement il fait preuve d'une certaine discrétion  |
Psyc | Citation :
...Mais à Marseille et maintenant à Lyon, c'est pareil. Quand on demande à Clarion où en trouver, ils te sortent une liste de feu vert et norauto énorme...
Il est dispo à salon de provence chez CarAudio |
Serval | Le prix P du 948 a baissé
C'est a 699 que l'on peut ce payer cette merveille  |
acousticodoc | Citation :
j'ai eu la chance d'avoir une plaquette japonaise de présentation du produit, hormis le fait que je bloque devant le japonais, au niveau filtrage c'est une petite merveille avec une gestion active 4 voies (avec de multiples config possibles)high/hpf,mid/bpf,low/bpf,sub/bpf avec pente de 6 à 18db,phase nor/rev, le poste est apparement livré avec alim déportée et certains composants interchangeables...
d'après le manitou produits europe la france ne le verra pas...mais certains voisins européens si...pour ceux qui aiment passer la douane...
ps: je pense que mister BN sait ce que je viens d'ecrire, ces infos ne lui sont pas destinées, elles sont juste là parceque j'avais envie d'écrire un truc vu que je m'ennuie à 7:41 et que je suis un chieur de première...  |
moana | 8O 8O 8O 8O 8O 8O 8O Citation :
j'avais envie d'écrire un truc vu que je m'ennuie à 7:41 et que je suis un **** de première...
Posté le: 14 Oct 2004 06:28
8O 8O 8O 8O 8O 8O 8O |
especiosa | Citation :
Partage pas tous les mêmes infos chez Clarion. Au mondial 2 commerciaux (pas des hotesse débauché pour le salon, mais des salariés clarion) m'ont dit que pour l'instant il n'était même pas prévu pour l'europe, qu'il n'ya avait peu de chances car pas assez "porteur", mais que Clarion était encore assez flou la dessus...
Moi je préfère ton info  |
bob_bipbip | Citation :
quel pays par exemple :?: (ca m'arrangerai bien que la suisse fasse partie du lots, ve que les magasin caraudio les plus pres de chez moi sont a geneve )
tien, ca fait encore une excuse pour allé acheter a l'etrangé:
c'est moin cher, les produit pas dispo en france ....  |
yo@nn | Citation :
c'est clair que l'on aura un meilleur mid/aigue avec ca 8) |
8O 8O 8O 8O 8O 8O 8O j'avais envie d'écrire un truc vu que je m'ennuie à 7:41 et que je suis un **** de première...
apparement je m'ennuie aussi à 6h28... |
acousticodoc | hugh!!
(ca m'arrangerai bien que la suisse fasse partie du lots, ve que les magasin caraudio les plus pres de chez moi sont a geneve ) tien, ca fait encore une excuse pour allé acheter a l'etrangé: c'est moin cher, les produit pas dispo en france .... _________________
1500euros  |
Serval | Le 9255 clarion, ce trouve en angleterre Pas trop cher en plus.. |
fbx1465448 | Citation :
Un lien ?
Un nom de magasin ?
Le prix ? |
Serval | Prix : 921 euro
combien tu me files pour le lien ? |
Serval | Il y a 2 models de 9255 , faut faire gaffe
Un vieux 20 bits , et un moins vieux 24 st'ouquette |
