Lau82, deadman8 et 24 utilisateurs inconnus
rech info sur soudstream scell 1000
n°145226
turbo57
Posté le 24-07-2008 à 13:41:02  profilanswer
salut a tous
voila je recherche toutes les info sur ce produit  surtout si c compatible en lieu et place de la batterie d origine
voila les info que j ai deja
si kkun pourrais m eclairer
merci d avance
Specifications:
# Satin Chrome & Aluminum Finish
# 16 Volts DC
# 3-6 Year Cycle Life
# Digital Volt Meter
# Distribution Block Terminals
# 1.6 Milliohm Int. Resistance
# 21 Amp/Hour
# Surge 1000 amp x 8 seconds
SCELL-1000 - Soundstream 1000 Amp Cap Cell SCELL 1000
Description:
After years of large capacitors being on the market, they still remain a mystery to many. Often called a power cap or stiffening cap, some people prefer caps over adding a second battery and vice versa. So, which product is a smarter choice? Neither! A second battery is a great option for high power systems, but should be accompanied by an upgraded alternator that can efficiently charge both batteries. This can get really expensive.A capacitor is similar to a battery but can charge and discharge in a fraction of a second depending on size. The cap has the ability to empty itself almost instantly on transient notes in music material. However, it does not have the stamina that a battery has and is not an equivalent substitute.
Our Cap Cells are a fusion of both products. The Cap Cell offers auxiliary power with the ability to enhance the transient notes, often suppressed in car audio systems with an OEM battery, while being able to reinforce the battery during long, intense bass notes. A second alternator is not necessary, making the Cap Cell a perfect addition and an affordable way to supply the necessary power for a system.
n°145229
bastenix
Posté le 24-07-2008 à 15:06:55  profilanswer
D'après ce qu'on lit, ça peut remplacer une seconde batterie+capa, mais pas la batterie d'origine : c'est bien une batterie "auxilliaire".
et 21Amp/h ça me semble vraiment trop faible pour une batterie principale, non?
n°145230
turbo57
Posté le 24-07-2008 à 19:55:45  profilanswer
ok mais je peux la mettre en serie de la batterie d origine pour alimenter la sono ?
n°145309
turbo57
Posté le 27-07-2008 à 20:09:07  profilanswer
personne peux m aider ?
n°145312
nevada man
Posté le 27-07-2008 à 22:25:35  profilanswer
Oula pas en série malheur! En série tu ajoute les tension, les batteries doivent êtres branchées en parallèle.
n°145321
turbo57
Posté le 28-07-2008 à 06:46:32  profilanswer
ben  LES PLUS ensemble et les masses a la CARROSERIE  en faite
