sull, CDS94, dusky Recherche de matériel : ALF 33 et 39 utilisateurs inconnus freijojo-307 | Reprise du message précédent :
bugs ears a écrit :
j'ai vu sa tout à l'heure sur son topic.c'est très bien réalisé,jolie cinématique mais a quoi cela peut il bien servir?
Ouai moi aussi j'ai vue ca, mais l'utilisation de celui ci reste un mystère |
cypt16 Dans une Suédoise.... |
J'utilise çà sur....un bruleur pour chaudière à vapeur dans une usine d'incinération!!!! On régule le débit d'air primaire dans la chaudière avec ce diaphragme régulant...
Mais je pense pas que le gars ai une chaudière dans ça caisse!!!! ---------------
"...La connerie, c'est comme le judo, il faut utiliser la force de l'adversaire..." (Jean Yanne.)
neoprene | http://www.motormusicmag.com/news/ [...] Sport.html
Tuning
Building a system is only one part of the overall result. Tuning is vital and fortunately Summers is an expert. “After the first install I did a basic RTA tuning on the system to a curve I had derived from my time with my Volvo install,” Summers reveals. “Time corrections were set by basic distance measurements. Crossovers were the Morel passives. I then spent the next two months listen to all kinds of music and tuning the system by ear.” He tinkered with the component levels for a better balance, focusing first on the stereo. “From my experience if stereo is not tuned correctly and imaging properly, 5,1 will never sound right.”
For reference, Summers used his home system. “A tuning session would begin with first reviewing the musical material on my home system and then going down to the car and listening for hours at a time,” he shares. Once he felt fairly confident with the stereo setup, he took an RTA reading and averaged them for the “reference curve.” He then could turn to the other speakers. After listen for a few months, he determined what limitations the system had and decided to rebuild it as noted above. “I also went active on the whole system, eliminating all passive crossovers except those for Left Rear and Right Rear,” he states. “The rear channels are bi-powered through the passive crossover to give better tuning capability.”
Summers likes to use a Gold Line RTA System which consists of a PC computer interface, a 4-microphone multiplexer, and 4 calibrated microphones. He takes his measurements using timed spatial averaging. “This is a much more accurate way to measure the spectral response of the sound system and is used in most hi-end studio sound system alignment,” Summers explains. “The four microphones are arranged in a 6-inch by 3-inch rectangle on a special microphone mount placed at head height in the driver seat position.” Summers ran pink noise through each speaker and mapped the response and amplitude before removing the passive crossovers in order to get a starting point for the active system.
Since then, Summers has spent countless hours listening to the system and fine-tuning the time correction, active crossovers, and overall system spectral balance. The result is phenomenal, in particular the amazing surround sound that truly immerses you in the recording. The editors here were most impressed with the imaging, the separation and the tonal quality. Frankly, we could sit for hours in this car, just listening to our favorite tracks and new ones.
“The audio system has come a long way in a year and a half,” concludes Summers. “It has taken a lot of time and patience to get it to this point. I am lucky to have met some real smart people in the pro audio and car audio worlds who have given me valuable advice as to how to bring the system to its present form. Aaron and Scott have stuck with me all the way with every re-build and system conversion.” With the Mercedes’ system this good, Summers has had to bring his home system up even higher.
sull người điều hành | spo un cache pour mettre au dessus du caisson ? ---------------
Nitroboomracer We have the power | il est quand meme long le monsieur
sull người điều hành | t'as fini de poser tes 18Wmachin toi ? ---------------
Faudrait deja que mes pieces arrive, et vu qu'il neiiiiige
freijojo-307 |
Oups le messieurs fait des mesures au lazer Sinon je croit qu'on est proche de la réponse a ma question :
1/2HS : Je trouve car même qu'ils se sont pas foulés pour le design des nouveaux human reign ! Les anciens été beaucoup plus travaillé; Mais certes moins discré du coup... Message édité par freijojo-307 le 18-01-2010 à 20:14:56 ---------------
musicamicalement ===Freijojo===
laurent-r |
These will be the 2 new amplifiers that will recplace the PPI.
As you can see, they are from JL Audio. The reason why? Simple, all the topdesigners from PPI work now at JL Audio.
2 years ago I’ve spoken with Jeff Scoon, the topdesigner of PPI. And I must say, from then on, it was in my mind of using JL amps someday.
The other option was the Focal Duo Monitor, but he has been for sale a couple of years now.
Cause this was only a 2-way amp, I had to buy one more to feed the subs.
freijojo-307 | Mouaip il a changer un gros ppi contre du jl ---------------
guesn | oue enfin passer la RS par l'habitacle faut y tenir quoi
encore que la RS en elle même ça va elle est propre ... mais la roue crevée ---------------
Romain
misterzubro | Pourquoi les Ricains mettent souvent les tweet en kick ? |
laurent-r | parceque ça te fait 3/4 de la scène tout seul, mais si ils avient pompé notre CC++ national, ils seraient en seat... |
laurent-r |
y triche il a une CN f1 pis dls pis revelator, fichtre
Nitroboomracer We have the power | |
misterzubro | Moi plus les Rainbow reference. |
Ludobrev | boomako a écrit :
Arc-Audio power in-side!!!
Merçi Ludo.
Il a le meme ampli que moi, et l'ancienne source et proc que j'avai.
Du bon matos en tout cas.
Boomako.
Il y a du nouveau!!! |
barracuda777 | Le nouveau joujou de Scott, lequel as gagne contre Mark Elridge et son jouet NASCAR en categorie Expert a la finale IASCA la semaine passe.
Entre autre un Denon DCT-Z1 modifie, un processeur audio pro modifie, 4 petit amplis Mc4000, un sub Fi de 12" et un ke Legatia L841-3 Pro SE. Les 8 en kick, les meds et les tweets en tableau de bord
http://www.buwaldahybrids.com/phpB [...] =26&t=5476 |
sull người điều hành | bah moi j'aime pas.
c'est du lourd, du très lourd, certe, mais ça me fait pas réver.
je sais pas, trop pro peut-être.
(jamais content ) ---------------
bugs ears | j'avais deja vu cette installation en cherchant des exemples d'intégration,mais la c'est du travail orfèvrerie. c'est magnifiquement bien intégré le monsieur est installateur, il de l'outillage et il sais utilisé ses neuronnes... Message édité par bugs ears le 23-04-2010 à 23:13:15
sull người điều hành | "des installes comme je les aime !" ce topic porte vraiment bien son nom !
Ludobrev | L'installe est superbement réalisée! |
sull người điều hành | les autres sont pas mal non-plus d'ailleurs ! http://simplicity.elitecaraudio.org/catalog.html édit : hésitez pas à clicker sur Install Gallery 2 Install Gallery 3 Install Gallery 4 Install Gallery 5 y'a d'autres trucs sympa !
Message édité par sull le 11-05-2010 à 01:37:27 ---------------
Clemouth29 Old school powwwwaaaa...!!!!! | pour la voiture et pour l'instal quel travail ---------------
Audison VRx.6.420.2 Champagne --> Focal TN51 et 6W2 Audison VRx.4.300.1 Champagne --> Focal 5WS et 27WX
sull người điều hành | t'as zieuter les autres ? vu qu'on a posté en même temps je suis en cours moa... ---------------
Clemouth29 Old school powwwwaaaa...!!!!! | toute les instals qu'il à fait un Julio américain  ---------------
sull người điều hành | je sais pas si c'est le même mec qui a tout fait, je cause pas anglais ce qui me fait chier, c'est que la moitié des liens renvoi vers une demande de login, et que c'est impossible de se "registrer" ... ---------------
Clemouth29 Old school powwwwaaaa...!!!!! | chez moi a chaque fois que je suis sur une page anglaise, allemand ou autres google chrome traduit et sur l'accueil il me traduit ceci HI!
Merci de visiter mon site web humble. Simplicité dans le détroit est un rendez-vous personnalisé voiture par facilité de l'installation audio situé à San Jose, en Californie. S'il vous plaît prenez le temps de lire mes principes et valeurs en ce qui concerne 12volts installation, puis naviguez à travers mon installer des galeries pour des exemples de mon travail passé. Si vous souhaitez planifier une installation, s'il vous plaît cliquer sur le rendez-vous le lien en haut de la page. S'il vous plaît également vérifier les témoignages de clients de lire quelques pages des belles choses de mes clients ont dit de moi dans le passé.
mais voilà c'est pro Message édité par Clemouth29 le 11-05-2010 à 02:01:46 ---------------
sull người điều hành | moi je lis pas, je regarde que les photos ---------------
